markwemple
- Apr 15, 2017
- 5
It's a 95 2185 with less than 500 hours. It ran fine when I bought it. Did a little cutting until it ran out of gas (too impatient). My boys decided to help daddy by "feeding it" and put grass, etc. into the fuel tank. I vacuumed that out. Then I did a "full service" - plugs, oil filter, oil, air filter, fuel filter, fuel line (all cub parts). When I pulled the stuff out, the old plugs were black, the air filter was completely clogged and the fuel filter had debris hanging out of it. Anyway, I tried to start it....can get it to run on starting fluid but not without. It appears to be getting good fuel flow into and out of the filter, and up to the pump. From the pump, it's decent but am unsure how fast it must flow. this is a kohler v-twin with a vacuum pump (not a fan). Pulled the carb apart, the bowl was a little low but that could be from me messing with it as I pulled it apart. Next I replaced the fuel pump. I now have plenty in the bowl and it's a little harder to start on fluid but will run a bit longer. The fuel shut off solenoid is working fine. I'm out of ideas!!!
