Greetings. I did a search but did not find any posts related to my issue.
I have a Cub Cadet SZ 54KH zero turn. I have done the basic maintenance I do seasonally, (Air/oil filter/oil change) I recently put new blades on it. The center blade seems to not cut like the ones on the outside. I isolated the center spindle and tried to move the blade, thinking it may be loose, but it is not. With the cover off and mowing I noticed the belt appear to be loose. Q Should the belt always be held tight against the outside pulleys?
Power issue: When mowing, not just in tall grass, I seem to lose power. I have to let off the gas and give the mower a chance to get RPM's back to normal. It's almost like I can hear a ticking sound. I have replaced the spark plugs this spring. They were purchased from the dealer when I bought the air/oil and filter.
I don't know what else to troubleshoot.
