Eugdot
At the end of last season I replaced both belts and stored it for the season after I winterized it. Today I used the snow blower for the first time since and it would not propel or revers and the Drive belt kept slipping off when in drive. I was able to throw snow but not able to move the thrower unless I push it with blunt force. I even went back to the old belts and the back belt the slips. Maybe its the belt tension spring that goes on the pully is bad? I adjusted the handle tension but still slips. any help would be greatly appreciated. it appears to happen when the disk tilts and rotates to the friction disk the belt seams to slip. the friction wheel doesn't look cracked or warn? and all the gears look aligned just a lost for what's happening.
Craftsman Snowblower Spring
Genuine OEM Part # 73204308C | RC Item #4370651
I think this is the spring, the pully reams to tensioner pully seams to rotate freely not sticking.
its a craftsman
model 247.881730
serial : 1/102b30631
its a craftsman
model 247.881730
