craftsman riding mower 917.270641- need help with blade engage/disengage
Sounds like you are getting there.
THe trick is to work on the deck while it is out till the engagement / dissengagement is smooth.
Some of the washers are stepped to provide clearance so do not tighten things up too much
Also because the levers only swing 1/2 turn at most you get uneven wear and rocking .
It is a tedious job because there are a lot of moving bits and each little bit of wear add up to the total problem .
I had one where the prime cuilprit was the brake pads themselves which had worn to a hook shape and when released got caught on the top roll of the pulley.
this ^^^^^^^
and dont be afraid to add thin ss washers on the deck surface if need be where things have worn into it and its draging on the deck surface. they will give you back just the clearance you need for it to move freely
just use common sense, grease everything well, and make sure everything free and easy before connecting the tension springs.
On decks, spray grease is your best friend
CRC do the best dry chassis litlium white grease and use plenty of it regularly.
