Hello, I am not at all good with doing any types of repair or adjustments on a lawn mower engine or the like.. I am a computer guy
But, I want to learn how to fix and tune, or at-least start with learning enough to get my craftsman mower running properly. The mower seems to have an Eager-1 engine. In order to get the mower to start, you must spray carb and choke cleaner into the carburetor which has had a part removed by a friend of my mothers that did some work on the mower last year. He said that was the only way to repair the mower and make it run. Then even once you get it started, it will stall right away if you do not pump the prime button continuously for at least 30 seconds while it is running. I am wondering if someone can tell me what I should replace/clean in order to get things running properly. I have tried to locate the air filter on this engine and cannot seem to find it, I read that it should be on the right of the engine and it should unscrew with a Phillips screw driver. Also, if someone can point me in the direction of a manual with illustrations of the common things that can be cleaned and fixed on this particular engine or at-least this type of engine. I am very new to this and am eager to learn with a bit of guidance.
Thanks guys and ladies![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Gary
Gary
