Craftsman M320 Burning Oil
TMan76034
A couple of years ago I bought the Craftsman M320, which has the "No need to change oil" engine from Briggs & Stratton. At first I carefully checked the oil, and since it never seemed to use any, I thought things were fine. They weren't. When I noticed some blue smoke coming from the exhaust, I shut it off and checked the oil - more than enough. Why? since I never added any oil. Well, I decided to extract the oil and add new. I removed slightly over 20oz of oil from an engine that only takes 15oz. Apparently, there has been some gas that is blowing by the rings. (I have St. Augustine grass and the mower works hard.) My suggestion to anyone that has this mower, check the oil level and if it slightly over the mark, change it.
Probably not blowing gas past the rings but has a carburetor float valve leaking instead.
TMan76034
Never thought of that, and there isn't a shutoff valve for when it isn't running. I'll pull the carb and check it. I really appreciate your input.
