Craftsman m250 self propelled.
Ronald B C
This self-propelled mower is only three or four years old. The opinion gear that fits in the pulling wheels is worn out and I can’t find one.. it’s part number in the manual is 175,103. The inner bore of the pin and gear has splines, and, of course the shaft that slides on is splined. If anyone knows where I can get two, I would really appreciate it.
May want to confirm part number by supplying us with the actual model number from the tag. But if the 175103 superede to 532175103 is correct it is NLA. And that makes the mower older than 2019.
Tiger Small Engine
The pinion gear can possibly be found on EBay used, if no longer available.
Ronald B C
The mower was purchased 3-31-21 I have the receipt . Will take a pic of the tag this afternoon.
Ronald B C
Here are the stickers that are on the mower.
Your original part number is for Husqvarna, but the model number tag shows MTD which the Spur gear is part number 717-05432 From this diagram
Ronald B C
Thank you so much !!! God bless you and your business!!!
