Thank you. I think the problem here is the ignition coil.When I do head gaskets & valve lash I raise the front of the mower about 6" to 1'
Even 4" ( a couple of house bricks ) under the front wheels will stop the oil making a mess
Noe if that oil is thin & smells like fuel then you have a carburettor float valve not working .
By the time you get done you will be ready to start posting you tube videos .
Do not get too prissy about the "tightness" of the feeler gauge
What I usually do is slip it in then tighten the gap so the gauge can not fall out then back off slowly till it slides out under the weight of the whole set .
Way back I was at an auto show where there was a competition stand where people could set a gap with a set of feelers which was then checked electronically
About 5% of the people who tried got it correct to within 0.0001 so went in the draw for a new car and less than 20% got it to within .0005" so got a pack of detailing products .
One of the rocker arms I could fit 0.009 in. I tightened it to where 0.005 fits and if I try really hard I can wedge 0.006 in there too.
The other rocker arm only 0.005 fit. So it seemed okay.
I'm on my second new battery now. The first one tested bad on my second trip to auto zone today. They replaced it under warranty. It was less than two weeks since I bought it.
I'm on my fourth spark plug. The original one went out in the trash. The second one is on the shelf. The third one I dropped and it shattered. The fourth one is in the mower.
I removed the carb, disassembled it and the interior was oddly very clean. The float is fine. I put it back together and didn't notice but I busted one of the screws in half. So it was constantly leaking gasoline. I fixed that today.
I bought the inline spark tester. Maybe it is DOA. Maybe I don't know how to use it. But with two different spark plugs and two different batteries, it doesn't do any kind of light show whatsoever. I removed the current coil and cleaned it. But that didn't help any. Nobody around here seems to carry the coil... websites say they can order it for $50. I bought one on amazon for $19... should be here for Sunday. Problem is that by Sunday my wife will have me renting a mower to cut the yard. This has been going on all week.
