Craftsman LT2000 -> Does not Start... Help Needed.
Stack223
The mower is now leaking gas out the side of the carb. Doh.
Stack223
I fixed the fuel leak and cleaned the spark plug. The mower still does not start. I tried cranking it with the rocker cover off and noticed oil coming out of the front. I don't think that's supposed to happen? I still think the problem may be too much oil remaining in the mower even though the oil level reads as normal.
Stack223
Just that top rocker is the exhaust and lower one is the intake. Cross flow head design.
I believe both of these should be set to 0.005. The top rocker I can fit 0.009 into. The bottom one is good at 0.005.
Could that difference on the top one legit be the problem?
Stack223
The rocker adjustment was a lot of fun and I did learn some stuff. But it did NOT fix the problem. All I can think of now is maybe drain the oil and start over?
Stack223
I'm going to go buy some new gas, another new spark plug and get the battery charged back up. But at this point I'm grasping at straws. If anyone knows how to start a mower, now would be a good time :)
You need to figure out whether you have a fuel or spark problem. You need to purchase a can of carb cleaner and/or an inline spark tester. Both can be purchased at an auto parts store. Insert the spark tester into the plug connector and check to see if you have spark. If you have spark, remove the air cleaner and spray some cleaner into the air horn. Let us know what happens and we can go from there.
Stack223
I did the carb cleaner already. The air horn is free and clear. I’ll look for a spark tester. I’m headed to autozone here soon.
Stack223
Okay have the battery all charged up, new spark plug, new gasoline and an inline tester. Will report again soon.
Stack223
We are getting zero light on that in line tester. I guess that means the spark plug does not fire. I feel like replacing the spark plug isn’t the anwser. So what do we do?
hlw49
Unplug the kill wire from the coil and check for spark again. If no them take the coil off and clean the mounting areas on the coil and engine block. Have heard this all my life but only got it to work one time. But worth the try.
