Craftsman Garage
- May 2, 2021
- 42
- 548
Alright, thanksBecause they are not saying for you to check for the ACR bump of the Intake rocker at TDC compression. Which if not there it then it doesn't matter where the intake valve is set but the standard for the intake rocker is .003 - .005 on the Intek engine and the exhaust is at .005 - .007. Intake rocker is one furthest away from the flywheel.
But charging the battery is a separate issue. The unplug wire connector may be to the stator (alternator). This engine came with either the dual circuit or tri circuit stator. If dual circuit there will a red and a black wire to the connector. Tri circuit has one wire and a voltage regulator. And voltage regulator must be grounded to the engine metal crankcase.
