Craftsman lawn tractor, No Compression on either cylinder
Johnnywjr
No Compression on either cylinder, Craftsman (917.270752)18.5 Hp Lawn tractor. Briggs and stratton engin (407777-0121-E5). what would cause no compression on both cylinders? I have verified on one cylinder that it appears the valves are seating as seen from rocker area.
Are the valves moving ?
had more than one come in being diagnosed as broken con rods when the actual problem was the flywheel has come loose & was not turning the crankshaft
I did assumed that since he posted the valves appears to be seating that the rockers are moving hence the crankshaft moving.
