Craftsman Lawn Mower
Jun
My lawn mower has a briggs& Strratton engine (Model #126L02-1528-F1). I am going to replace the cylinder head gasket. How to find the bolt torqe sequence? Thanks.
You will need to find a manual on line some where.
I rarely bother.
You undo from the outside in and do up from the inside out.
make sure the engine is stone cold and work in a criss cross pattern.
Undo them in stages, 1/4 turn each twice then right out and do up in a similar fashion.
