artemjemmy
I thought the current standard procedure was to replace either DSAI or DSAM systems with the newer and simpler MDI system, which only requires a ground wire.According this mower came with a Kohler CV16-43514. This has a DSAI or SAM ignition system and not MDI system. Depends if it been converted or not so will have two control wires or three controls wires plus the HV lead for spark plug.
The Sam control box is no longer available which is why Kohler is now sending out the DSAI conversion kit when the control box fails.
This is the SAM ignition module.
And this is the DSAI ignition module conversion kit
View attachment 59798.
The MDI system does not require a positive supply either. I think parts dealers are still selling this DSAM to DSAI system (even though it is obsolete), because they still have stock.
