- Nov 29, 2014
- 24,995
Hey Berts. Yes, I'm still dealing with this junk when time allows. I can't find it but in one reply you said this ignition switch has one stand alone white wire. Mine doesn't. Hopefully the attachments get through and clear enough to see.
Hope your wrenching is better than your photography :laughing:
Take the red plug off the ignition switch and in good strong light you will see tiny letters on the back.
These will correspond with the little chart at the bottom of those circuit diagrams.
Take a photo of the back of the switch & the front of the red plug.
Put your camera on a stand of some sort & focus it.
If you are using your phone, straddle a step ladder over the mower and lean your hands on one of the steps to steady them while you focus & shoot.
AS for the other two photos, zoom out a bit because I need to know where those wires go. A plug is a plug is a plug.
