craftsman 7.25 burning and leaking oil out of exhaust
Tcasa
  • / craftsman 7.25 burning and leaking oil out of exhaust
:thumbdown:
My year and a half old craftsman 7.25 platnm. series mower is burning oil and leaking oil out of the mufffler at start up.Problem is intermittent.
Changed the oil at end of breakin period last spring ...... changed air filters at least 3 times.Changed oil this spring ..... new plug and filter.Mower starts
at first pull.Love this mower,but very disappointed with oil problem.And NO .... the oil is not over full
reynoldston
Sounds like a internal problem. Bad piston rings or piston. Take the head off and take a look at the cylinder walls. You might want to check the valve guides when you have that head off also.
Tcasa
Thanks ........ shame ..last craftsman i will be buying
Tcasa
Is it worth having repaired?????
reynoldston
Craftsman didn't make the engine. If that brothers you don't buy your next mower with whatever engine your Craftsman has. Sears sells a good mower. Is it worth repairing is something I don't know. Are you going to do your own work? or take it to a shop? A year and a haft old mower, if it was mine I would repair it but I do my own work also.
Year and a half old mower may have some warranty left on it. So having sears look at it may not be a bad thing.
