Always run at full throttle. If the choke is on the same lever then run in the top notch before choke.
If the blades spin easy then the brake is off/ok.
Yes, choke is on the throttle lever so I run at the top notch (i.e, the 'rabbit')
If a Sears tech told you everything is right, then there should be no problem, as they are experienced techs and you believed them? Yes, I'm being sarcastic, wouldn't be the first time I've clashed with those guys. Did they see it clumping, if so they would not have made that statement. In cases where I have seen your problem, the causes are those I asked about. Blades not turning fast enough, decks that are level front to rear, when the rear should be 1/8"-1/4" higher in the rear. Who checked the level and how did they do it? Wrong or dull blades. My questions would be, does it always happen in the same area? Do the blades seem to retain their speed when it happens? Does it happen when turning, going straight, up or down slopes, all of the above? Is your engine always running at full throttle? Draw me a picture as to what is happening, as I'm not standing there to see it.
You cannot even find the socket size needed to change from regular to mulch blades anywhere on any Sears site, which is ridiculous.
Carscw, you bring correct knowledge to this discussion. Craftsman recommends running at full throttle, and using the motion lever, or speed pedal, whichever you have, to slow the mower down. You only need to throttle it down when you are getting off the tractor to pick up branches and debris and throw them out of the way so you don't run over them, which can cause a host of problems. And even then it's not necessary to do so, but why have a motor running at full speed for no reason, if it's going to take you five minutes to pick up branches? I prefer not to shut the mower off, as it is less wear on an engine, starter, etc. to just leave it running, but at a low speed while stationary.
For fear of starting another war, it is not good to run the engine at low idle for extended periods of time.
At low speeds it gets insufficient air over the cylinder to cool properly.
It should say similar in the owners manual.
It is your mower and you are entitled to do with it as you see fit, but it is not good practice.
