Craftsman 22hp kohler command mower loss of power when pto is on
mwhitnell
My mower loses power when I switch on the pto. when I cut sort of heavy grass the mower bogs down, like the governor is not switching on. I checked the governor and and checked the adjustment, but I see nothing not working. I was wondering if I cann just hook the throttle to the carb and bypass the governor.
NO. The governor needs to be in place to both control engine speed based on load and to also prevent overspeed. I suspect that your engine is running on one cylinder only, which for most people is hard to detect.
mwhitnell
You know that was my first thought...I removed plug wires one at a time, one killed the engine, the other kept it running. Good catch.
