- Sep 24, 2017
- Threads
- 286
- 6,864
143.666072
Craftsman engine made by Tecumseh...
Odd spark issue... new OEM points and condenser and coil.
Point gap set at highest point to .020".
The spark will not jump a gap... only if i touch the metal spark plug connector on the end to metal and i will see a bright blue spark, but it just will not jump ANY gap.
I'm noticing that the flywheel magnets (flywheel has 2 magnets) have been reglued with a hard steel epoxy... I was wondering if they were put in the wrong order could this cause a weak spark issue, or would that result in a complete no spark issue?
Thanks!
Thanks!
