BRIANJBOLL67
- Apr 30, 2023
- Threads
- 1
- 8
IHAVE A RIDER THE MOWER CRANKS WONT START ITS GETING FUEL TESTED FOR SPARK NO SPARK REPLACE PTO SWITCH MODEL 917204010 JUMPED NETREL SWITCH SEAT SWITCH????????
THE MODEL OF MOWER IS 917 204010 CAN YOU GIVE ME A PART NUMBER FOR THE SWITCHNot straitforward plug & play but I have done quite a few
Easy ( expensive ) way is to buy the key switch & wiring harness for the same model that does not have the STUPID SWITCH .
They gave so much trouble they were dropped and the mowers went back to normal electrics
The harder way ( but cheaper ) is to buy a standard switch, some wire & terminals
Depending upon exactly which model you have some have the standard key switch plug and a pig tail to connect it to the Stupid Switch sp check the number of terminals and their positions before buying a new switch .
hi do you have the part numbers for the switch and harness???? so i can into thatNot straitforward plug & play but I have done quite a few
