Chris Hunsaker
- Apr 2, 2012
- 1
- 2
I have a Craftsman lawn tractor with the Briggs and Stratton 19 hp engine model number 42A707-1625-01. The engine will turn over (power to the starter, starter engages and turns flywheel) but the engine won't start. I have replaced several parts in the fall. The solenoid (it started a few times, then failed to start) and the "coil" (I guess) and spark plug wiring harness (this was one piece) and it did the same thing. Ran a few times, then failed to start. I have just rebuilt the carb. The engine will turn over, but won't start. I don't think I'm getting spark at the plugs (I pulled one, connected it to the lead and grounded it on the block; no spark). It smells like I'm getting fuel in the cylinders when the engine turns over. Any suggestions?
Thank you,
Chris
Thank you,
Chris
