- Nov 29, 2014
- 65
- 24,995
The main jet has fallen out or when cleaned has been enlarged
The float is not cutting off the fuel supply at the right height so the fuel is higher in the bowl
Both of these will cause the engine to miss & blow smoke filter on yet run fine filter off.
Excess blow by can foul the plug causing a miss fire filter on as well but you are getting into lottery winning odd on that one.
