pickenspolitics
- Jul 1, 2012
- 4
- 23
I have a 42" cut/ 14.5 HP 917.270532 riding mower.
When I park it the battery will be fully charged, but two weeks later the battery will be dead. I changed the battery and the amp meter shows it is charging when the mower is running.
This only happens when the seat is down.
My hunch is the following... The grill is missing and the wire to the front lights is not connected to anything. See photo (you'll see the loose wire in the bottom left).
Do you think that is the cause? If so, can I plug that wire? I don't plan on spending the money to buy a grill with lights (never cut at night).
Do you think it is the seat switch?
Any other suggestions?
Alex
Alex
