- Nov 29, 2014
- 24,995
That's great info. Thank you. I'm going to call them and see if they can order them in. Do you have a part number of the blade holders? My shaft basically is shaped like <O>. I'm not sure what they call it. I'm sure I can make something out of flat bar steel if I have to, but it would just be easier to buy them pre made if they are available. Thanks for the help. I really like the swingback blade idea.
The carrier will depend upon the mower.
You can not use plain steel unless it is hardened and tempered.
Like I mentioned, bar blades are boron steel & heat treated.
The blade converion kits also called Composite blade bars are a local product I get from Roy Gripskie & Sons http://www.gaspares.com.au/
Go to that web site and type BLH in the search widow then select "by GA Number" from the drop down.
Most of what you are looking for will be on pages 4,5 & 6.
Note that the BLade Holders in this section also include those for walk behind mowers all mixed up
Also check code CBB
