Hi,
I have recently purchased a Countax with a 13hp v twin Honda and I'm having engine issues. The engine starts ok when cold, but cuts out and struggles when warm. It also backfires and struggles to restart when warm and when it gets going it refuses to rev up to properly. the throttle response is very slow and it kind of sounds like the choke is on when it isn't if that helps. when the engine is put under any strain by the PTO or cutting blades it struggles to stay running. It has new plugs, new petrol, airfilter. I have cleaned up the carb as good as I can (i'm relatively new to small engines). Any advice would be helpful. I can upload a video if it is helpful.
Thanks
Sam
Thanks
Sam
