Hello everyone. First post. Long time e-power user here - just not for lawn mowers - yet!
I just ran across this thread searching for information on modifying the batteries on cordless electric lawn mowers. There isn't much information out there - at least not specific to modding a newer cordless mower.
I dabble with e-power as a hobby (electric model aircraft and ebikes) and don't like noisy mowers. So a cordless mower seems like a logical choice. The lead-acid powered mowers are heavy and duration is poor. Gotta fix that...
I just ordered and received a B&D RB-3610 replacement battery assembly to see how easy it would be to replace the batteries in it. This fits the B&D CM/SPCM-1936 models. It is roomy inside so it looks like it will be pretty easy. So I'll proceed and get an actual mower.
In approximate terms, the initial evaluation shows that with LiPos, the battery capacity can be doubled while halving the battery weight. By the time all miscellaneous components, taxes and shipping are paid, this will cost around $400. That's not cheap, but then you've got a cordless mower that can be charged in an hour that should be able to mow a large yard (or perhaps an average yard a couple of times). And the OEM battery that comes with the mower is also available for use.
The nominal voltage will also be a bit higher but more importantly, the voltage under load will be considerably higher given the extremely low internal resistance of the LiPos. This should translate into less bogging in thicker grass.
I would consider some sort of "watt-meter" mandatory on something like this. I'll throw on an old Astro Wattmeter on it. This will report voltage, amps, power and capacity (Ah). I would attach it to the top of the battery enclosure so it can be viewed in use.
Anywho, I'll start ordering the materials this weekend. It could be a month before I have this done as I'll have to wait for the batteries to ship on a slow boat from China.
More details to follow...
Rob
