OutdoorEnvy
- May 5, 2014
- 10
- 102
So I went ahead and decided to drill some holes in the deck so the B&S engine would fit and got it installed. The brake cable is awfully tight using the original snapper cable. I think I'll drill a new hole about half an inch from the current hole to lessen the tension on it. I did have to move it to the other side of the handle as well. But other then that I just need to get a 21" high lift blade and it will be ready to use. I sprayed the bag down pretty good with the hose and it looks much better then it did. The makeover restoration will be next months project. I am excited to see how it mows though now that I can use it
So here it is...ugly but in a nice way I think, it's kind of Christmassy with the red and green, haha! The green engine cover will be painted white when I refinish the deck and handle. That should match nicely as I've always liked the white engine look on the old snappers.
