Continuous using air filter
jcworks
2013 Toro MX5060, Kawasaki 23hp. Sometimes it gets real dry and the mower kicks up a lot of dust, especially under all the big trees I have. I take off the paper filter and tap it on a tree trunk getting a lot of dust out of it. I have a foam pre-filter on it but lots of dust still is on the paper. Question is how does one know when to toss it and get a new one? Or can you keep using it like this?
Skippydiesel
Tough question as every situaton is diffrent.
The more a filter catches the cleaner the air so you won't damage the engine.
I guess you will have to be guided by how the engine is running (after filter tapping/cleaning with compressed air) -
Does it cold start without the choke ? - this might be an indication that the filter is restricting air flow too much - change the filter.
Engine not making full power/rpm ? - could be an indication it's not getting sufficient air for good combustion - change the filter
jcworks
The engine runs fine. Between mowings I sometimes have to choke it; other times it starts without choking. Either way it runs good. I'll just get a new filter. This one's been on a couple of years.
Dust on the outside of the filter actually makes it work better
Dust on the inside of the filter means the filter has a hole in it and needs replacing .
A filter is clogged when the mower starts to blow black smoke like the choke has been left on for too long
