Compression testing question
Romey55
Question, i have a troy bilt ,ryobi and bolens weed eater (which i found on the road ) . If i screw in the compression tester all the way in on the ryobi and bolens , i cant pull the string . No problem with the troy bilt . If i unscrew the tester a few turns i can pull the string . Does it matter ?
YES with a capital Y
To get meaningful readings on these very small volume engines you need heads for the compression tester that are exactly the same size shape & volume as the spark plug .
So my set has 4 heads it came with and a dozen more I made
Plus it must be sealed and it matters where the check valve is located in the hose. It must be at the cylinder end and not at the gauge. I use an Actron tester and never had a problem like you describe.
