What the heck...Carb linkage wrong
Govenor out of adjustment
Wiring just f'ed up
Gaskets missing or incorrectly installed
2 stroke fuel lines on wrong
Wrong part
Wrong belt
Wrong spark plug
Stripped fastners
Switches bypassed wrong
Electrical tape on wire connections
Parts on backwards
Like others have said. Most folks can't troubleshoot problems logically and just guess and change parts. I usually spend more time figuring out what they did than fixing the problem.
The first mistake they make is.......opening their tool box!So--- Pros:
What are the common mistakes made by amateur repair people?
Diagnostics code on the invoice is Operator Headspace and Timing.About a month ago, a guy brought in a zero turn mower in that he bought from us, and had it 2 weeks. It had quit running in the middle of his mow, and this guy was pissed off about it. He had to get help to push it on the trailer to bring it to us. He was so pissed off and mad about it that I just let him and his sidekick push it off the trailer in the back lot. A day later when I looked at it, it was just out of gas. Being a business, you can't tell someone how stupid they are but...I didn't need too, he knew it and was calm when he picked it up!
Should of gave him an hour minimum charge and seen how his temper stayed..?About a month ago, a guy brought in a zero turn mower in that he bought from us, and had it 2 weeks. It had quit running in the middle of his mow, and this guy was pissed off about it. He had to get help to push it on the trailer to bring it to us. He was so pissed off and mad about it that I just let him and his sidekick push it off the trailer in the back lot. A day later when I looked at it, it was just out of gas. Being a business, you can't tell someone how stupid they are but...I didn't need too, he knew it and was calm when he picked it up!
Probably would've had to call the cops...I try to NOT, escalate problems if at all possible....people are on the very edge in todays society!Should of gave him an hour minimum charge and seen how his temper stayed..?
