glwilliams58
While mowing yesterday, my CH740 27hp shut off.
From that point on it would start each time I turned the key, then shut off.
I checked the oil level thinking it may be a safety sensor for low oil. Level was fine.
I check the fuel filter, thinking it may be running out of gas. Filter and fuel flow was fine.
It will start every time you turn the key to START, but as soon as you let go of the key and it goes back to the ON position, it shuts off.
I found that if you hold the key in the start position, it will continue to run as long as you hold the key in the start position.
What do you think is causing this problem?
Thanks,
GW
Sarasota Florida
Scag Turf Tiger STT52V 27CH
2006 Command Pro 27
Model# CH740
Approx 720hrs
Thanks,
GW
Sarasota Florida
2006 Command Pro 27
Model# CH740
Approx 720hrs
