- Sep 24, 2017
- 250
- 6,445
I don't have the necessary equipment to put the z bend ends on the cableAs long as the outer is fine you can replace the inner
I do it all the time
Nor do most of us have a way the cast these on those flexible wire cables which why I replace several cables every year here.I don't have the necessary equipment to put the z bend ends on the cable
