mng519
- Jul 26, 2021
- 4
I switched from lead acid batteries to lifepo4 lithium iron phosphate. The positive connection gets too hot and ruins the cells causing them to start emitting a noxious smell similar to lawn poison. I've tested all of the connections for any resistance and they all come up fine. Voltmeter reads 0.00 for no resistance. I was able to use the batteries for a pretty long time in the beginning of switching over to lifepo4 without noticing any problems. Now I can't mow for very long at all before the problem occurs. Can wires degrade over time causing an overheating issue with the positive lead? I'm ready to start replacing the wires to see if it fixes the problem.
If anyone knows anything about this issue, any help would be appreciated. Thanks.
