Click Behind Dash No Crank
If my memory is still working I believe it is a #50 Torx bit.
I had some spare time especially something on my air compressor blew and I have dig it out after the rain. Went and measured my Torx T wrench and it is a T40 that I used to remove most of the Briggs starters.
Little trick is to wind up the bendex to the top of the shaft which will give you clean access to the bolt using an extension on a short socket
Even when using a torx driver it is easier if you move the pinion up out of the way
bk10s
You guys are so smart...Thanks again!
turbobike1
dirty contacts somewhere.
AGREED ! I have a Craftsmen 26 hp lawn tractor w/B&S engine. it is 16 yrs old, and I have replaced the ignition switch twice already and it needs another now. It was a dry dusty summer and all the crap gets into everything, including this switch.
