Choke spring location
Wallus1
Hi folks. I removed the carb from a B&R model 124707-0215-01 engine that's on an old DR. Power Wagon. The choke return spring fell off and I cannot figure out how to install it. Can anyone come up with a diagram for it. I downloaded the parts manual but although it shows a picture of the spring, it doesn't show how it hooks up.
Thanks, Wally
Scrubcadet10
Moderator
Staff member
I typed in your model number on multiple sites and none of them had the engine with a choke, only Primer....
If this is in deed a auto choke engine, this should help.
Wallus1
No. It's definitely a manual choke.
Scrubcadet10
Moderator
Staff member
ok my bad, i did not see there were 2 sections in the IPL, one for the choked carb, and one for the primer carb.
Personally i've never worked on one with a manual choke so i can't tell you. but I'll bet you some of the other guys on here can.
Wallus1
Ok, thanks
Wallus1
