Ome of my riders, Husqvarna YTH 2348,  has a charging issue. With full throttle at battery terminals same voltage as wihtout running at all. Battery will die with continuous use. I have replaced the voltage regulator, no change, battery is new. There are two white wires (smaller wires) coming into voltage regulator that have no voltage on them while running, I am assuming those are charging wires and should have 18V or so coming in. I have read that this cvould be faulty ignition switch or obviously could be stator, anybody know how to test the ignition switch or narrow this down more?
