Can a deep cycle battery be charged with any charger or does it take a special charger, thanks
M mowerman05 Well-Known Member Joined Mar 7, 2013 Threads 34 Messages 466 Jun 13, 2013 / charching a deep cycle battery #1 Can a deep cycle battery be charged with any charger or does it take a special charger, thanks
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,768 Jun 13, 2013 / charching a deep cycle battery #2 You can use any charger, but I would section the lowest amperage possible and charge for a minimum of 24 hours.
Ric Lawn Pro Joined May 7, 2010 Threads 142 Messages 5,765 Jun 13, 2013 / charching a deep cycle battery #3 You can buy chargers with 2, 10 and 15 amp charging cycles. and if you can also buy with a 50amp starter charge so you can jump the car if need be. Like Rivets said pick you lowest charging cycle and charge for 24 hours.
M mowerman05 Well-Known Member Joined Mar 7, 2013 Threads 34 Messages 466 Jun 13, 2013 / charching a deep cycle battery #4 thanks guys, I thought so but just wanted to make sure.:thumbsup:
