Changing oil in in a Magum 2760.
1dave
What is a easy way to get the oil from the drain tube at the bottom of the engine. It is behind the frame and the tire is in the way on the left side looking at it from the back. Is there an extension tube I can put on it so I do not make a mess. Is there a video I can watch.
I do find that a lot of the manufactures don't give changing oil much of a thought. Me being a shop where I have a lot of different brands and models I made up a trough out of flashing. You might want to make something out of pipes.
Thanks, I will have to sit down and look at it and maybe something to it
