Had something interesting yesterday while putting carburetor back on. While I was installing I broke the ear off the insert where the choke linkage attaches to carburetor. Since I was "down" until parts to repair the choke came in I decided to play with the jetting. Keihein main jets in motorcycle carbs are the same as the one in this carb. I put 2 different bigger size jets in and it made absolutely no change in the way the engine ran. Expecting the bigger jets to cause the engine to load up with fuel and run rich it didnt happen. I took an unmarked jet and drilled it out to 1/16" installed it and it still made no difference. The only way to get the engine to load up with fuel and puff black smoke is to choke it. Im beginning to think I still have a restriction in the high speed circuit. Sounds like a new carb might be needed.
