trooper1954
- May 29, 2012
- Threads
- 42
- 186
Hi Guys,
Have a real problem here. Included in the photos is the drive shaft and carrier plate from a stihl wheeled trimmer. The machine hasn't been used for some time, and the bearing inside the carrier plate has seized. I've tried just about everything I can think of to break it free.....soaked 48 hours in Move it, heat with a torch, and also a puller.d as you can see in one of the photos, while using the puller it slipped off and damaged the head of the jack shaft. There's enough thread left that I hope I can still use it, but I need to get the carrier plate off in order to replace the bearing. The cost of a new jack shaft and carrier plate is almost half the cost of the machine. so I'm not feeling real fuzzy about that one
If anyone has any suggestions that I haven't tried I'd appreciate the help.
Thanks.
Thanks.
