Jb7054
- May 9, 2020
- 5
I’m not too familiar with carburetors but I’m trying to fix surging on my lawn tractor. It’s a B&S 21hp single cylinder with a Nikki carb. I’ve made some adjustments but I’d like to understand what the screws I’m turning do. On the carb there are two screws. One comes off at an angle with a plastic end on it. It doesn’t turn much but doesn’t seem to have much of an effect on the engine as it’s running. Above that is a screw with a spring. It seems to limit how far the throttle can open. The more I tightened that screw the less erratic the engine ran. With that screw completely tight the surging is just about gone but I feel like that’s basically choking the engine.
