If you have a genuine tecumseh adjustable carburetor (two-needle), then clean the jets and emulsion tube holes squeaky clean, and you should be golden. If there is any sign of even the slightest tinge of green inside the float bowl area, the pinholes in the emulsion tube and jets can be plugged. Unless the bowl is leaking or you damage a seal taking it apart, you shouldn’t need to kit it. Just clean it out. If you have a fixed jet type of carb as found on more modern units, you have to make sure the idle jet plug (tiny pin holes; like 4-6 of them, located where the idle needle would go) is squeaky clean because this does have some interference with the high speed fuel circuit. Next, clean out the pin holes and center bore of the float bowl nut which is also the main jet. The emulsion tube on these is often plastic (mine have been green plastic), and is not removable without destroying it. Run a pipe cleaner up through it with some solvent and that should be all it needs. I’ve got one of each carb type on the two units I currently have (Tecumseh HM80 Snow Kings), and after cleaning the green crap out of the fixed-jet carb, it runs as well as the adjustable. To prevent these carbs from ever being problematic again, install a fuel shut-off valve if not already equipped, and use it when done for the day. Turn the fuel off, and let the engine run the carb dry every time. Use fuel with STA-BIL added at 2oz per gallon of regular gas and running the carb dry every time will give you 20 years of service without ever having to open it up; this has been my experience with this adjustable carb I bought new 20 years ago that costed $85 back then.
