- Sep 7, 2024
- 3,313
What are you applying pressure to? I assume you mean positive pressure above 0.
The weight of the float is not as important as the buoyancy of the float when in fuel.
Other than that, the float level in relation to the housing is normally measured with the carburetor bowl removed
