- Sep 7, 2024
- 3,458
A carburetor "overhaul" with new parts does not always fix the carburetor.I bought a used machine with a B&S 305 CC 1350 series OHV motor. It ran like a top, until I brought it home, filled the gas tank, and left it for a day. The carb leaked fuel all over the floor. After installing a carb kit, and trying to restart, it locked up on the compression stroke: turns out the cylinder was completely full of fuel. I could rotate it backwards with the crankshaft pulley bolt, and after working it back and forth for some time, the gas cleared out of the muffler and I could rotate it. Then I restarted, and it ran super rough and belched white smoke. I checked the oil, and found that a half quart of fuel had gotten into the oil, it was now nearly twice too full. I drained the contaminated oil, flushed the crankcase a couple times, and refilled to the right level. Still runs terrible and blows tons of smoke. I turned the crankcase breather around so no oil mist could get from the valve cover to the air intake, with no success. Every once in a while it revs almost to full RPM and runs nearly clean for a few seconds, then starts misfiring and smoking like crazy again. Thinking there must be some reservoir of oil under the valve cover, or in the intake manifold, or maybe I installed something wrong on the carb, I dismantled the whole thing, and everything looks clean and correct. There are no oil pools except by the valve guides (just above the manifolds), about 1/2 tsp in each. I cleaned that out, reassembled, and tried again. It started rough, then cleaned up and ran so-so, with not much smoke, but instead of cleaning out and running normal, it started running worse and worse until it finally died.
My question is whether it's possible that filling the cylinder with liquid fuel and then running it out past the valves could have caused permanent damage, for example to the valve guides, that then allows raw oil into the intake manifold or cylinder? Or whether running even briefly with gas-diluted oil could have done something permanent?
One thing that is often overlooked is cleaning the float needle seat with a Q-tip and a little carburetor spray. I've learned that over the years, especially dealing with ATVs and 4-wheelers. The same problem happens with mower engines, but not as common.
