- Feb 19, 2020
- Threads
- 122
- 12,902
I didn't about the gasket being 180 out but yes they are slightly different. Only seen a couple customer installed the wrong way. Governor should be fine if not surging. Idle speeds may need adjusting but requires a tach as you got to set the base idle and the governed idle speed. If not done properly you can get some running problems like one one that won't idle down or won't idle down after it warms up..
