OK, so I feel like I have tried everything. I was recently gifted a used Ariens self propelled mower, manufactured in 2005, with a Briggs and Stratton 6.75 Intex OHV engine. When I got it, I put some fuel into it and was able to get it started. It ran for a few minutes, the idle speed dropped, and it eventually cut out. Since then, nothing. It sputters, but I cannot get it to completely start. I have replaced the carburetor, made sure it is getting a good supply of new clean gas, checked the air filter, replaced the spark plug and checked for spark, checked the timing and flywheel key, and changed the oil. The compression seem to be decent, though I do not have a compression kit to officially test. When I try to start, it sputters a little bit and very small amounts of white smoke puff froth the muffler. Even when spraying starter fluid into the spark plug chamber,it will not start. I am at my wits end and want to get it running. It all seems to be clean, clear of debris and in good shape does anyone have any ideas? Thanks!
