Bart is right..
You will have to do a bit of measuring & a little research...
You need to determine your wheel Size, Offset, Bolt pattern, Center hole size.
Most manufacturers do not make their own wheels, wheels generally last much longer than mowers... There are LOTS of used wheels, (usually with replaced tires on them) for sale on Ebay, at very good prices.
The problem is ... most sellers do not list what size their wheel is, only what they came off. So you will have to look those things up & know what size will fit yours and the others that share the wheel tire you want... You can end up with exactly what you want if you look around AND know what you need... :smile:KennyV
