patrickd5188
- Apr 22, 2020
- 2
Im almost certain the answer is no, bc I see a lot of mention about making sure your replacement engine has the correct crankshaft as well as other matching dimensions.
Need to replace the engine and would love to upgrade it and get more horsepower, but cant find any answer as to if this would work? I know the 7.25 is a Briggs engines so I would think the bolt pattern would match.
Also I noticed the 7.25 comes with a throttle lever, so I might have to adjust my 6.25 lawn mower frame that doesn't have one to accommodate the larger engine. I know the 7.25 has one but not sure on the 6.75 engine Husqvarna uses. Which I would gladly add/upgrade if I could increase my Hp.
If this just isn't possible, I'll try to order a matching (6.25ex) engine instead just like it has now. Saw somewhere that the 6.25 was discontinued by Husqvarna. Dang just also read that Husqvarna has begun phasing out all gas driven walk behind lawnmowers. Hopefully that wont make finding a Briggs engine anymore difficult if I do have to back with the 6.25. I've read they had alot of problems out this model (6.25ex), which i guess makes me feel better, that it maybe wasn't my fault it stopped working. But really wondering now if i even wanna go back with the same engine, if it was know known to have issues.
