I have a '76 model 7264. It has about 25lbs compression. The cool checked good, but I can spray fuel mix into the cylinder and it still won't try to start. If I want to get it running again, I'll have to put new crank seals/bearings, and a new set of rings in it. It prob wouldn't hurt to lightly hone the cylinder walls either.
Thanks, again, Fireman. You've been great help the last few days. Can I hone the cylinder wall myself, or should I take it to a machine shop? So, I might be able to use the same piston? ..... Just put new rings on it?
Regarding your 1976 model with 25 lbs compression --- are you going to purchase the parts and get it running again? If so, I'd like to hear how that goes. Is it easy or difficult to put in the crank seals? I'd love to get my second model 5247 running for a back up. Like my other 5247, it's a 19" push model also. I imagine it will need the same things your 1976 model needs.
I'm working the bugs out of my good 5247 that I recently got from a buddy who passed away. Advice from fellows on the forum has gone a long way. A new needle & seat stopped gas from leaking into the foam filter. I think I may still need to tweak the adjustment of the carb. I got rained out yesterday. I'm sure happy to have it running. Hopefully, it will last a long, long time. The pic for my avator is it.
When my 1973 model 5241 gave up a few days ago, it was like a death in the family. Ha! Genuine grieving! :frown: I'm hoping a new coil might bring it back to life. Its still got 95 lbs compression after all these years.
