neighborbill
- Jun 17, 2012
- 107
I have read and have removed and replaced a starter motor on a BX1500 Kubota.
It is a nightmare because of room spacing.
I know now that the contacts on my solenoid are not making good contact when I try to start.
Without trying to remove the starter again. Here is what I am thinking of doing.
Buying a three terminal starter relay. connecting the B+ from the starter motor to the B+ on the new relay.
Then connecting the other side of this relay to the starter motor. Effectively by passing the contacts in the solenoid.
I will make a parallel connection to both the new solenoid and the old solenoid. This will engergize the plunger to the fly wheel. and at the same time close the new solenoid contacts.
When the motor starts, pinon falls back 5 volts to solenoids (because the starter switch is disengaged) is broken and the motor starts.
What do you think.
What do you think.
