neighborbill
- Jun 17, 2012
- 12
- 90
I probably didn't make it clear.
I will be paralleling the 12 volts from the now connected solenoid so that the plunger will operate, to the actuator coils on the aux relay to the key 12 ignition pin.
Therefore the solenoid will activate on both original and aux at the same time. This will by pass contacts in the existing solenoid and instead placing a current path from the battery threw aux contacts to starter motor. Effectively by passing the solenoid contacts on that starter motor now.
You indicated there is a solenoid on the starter. As you were already told, the solenoid shifts the drive into the flywheel, thus you cannot eliminate the solenoid. Take the advice of someone who has rebuilt thousands of starters. if it is a Denso starter, the contacts may solve it. If you replace the solenoid on another design/OEM starter it may resolve it.
